O
OLIVER DEASY
- Messages
- 7
Did mine last week & didn't have any problem other than it was pain to get the shelf into position past the brackets. Would have been easier to put the brackets in one side, rest the shelf on those, support shelf with one hand, put final 2 brackets in drop shelf down onto those two.Just tried to move the shelf in my Ocean 6.1 to the top level above the. portapotti. Having a problem fitting it, there’s what looks like a small wiring junction box on the back wall which obstructs the shelf. Has anyone managed to fit it somehow or do I need to make a cutout in the shelf?
I guess they must have fitted the cable higher or lower in yours - I’m definitely going to have to modify the shelf to get it low enough to fit into the rear clip.Did mine last week & didn't have any problem other than it was pain to get the shelf into position past the brackets. Would have been easier to put the brackets in one side, rest the shelf on those, support shelf with one hand, put final 2 brackets in drop shelf down onto those two.
I'll take a photo later - can you take one of yours to compare?I guess they must have fitted the cable higher or lower in yours - I’m definitely going to have to modify the shelf to get it low enough to fit into the rear clip.
