VCDS Right Hand Actuator Coding
LRGS253
LRGS253
Christchurch, Dorset
My right hand actuator is going past its warm stop and causing the arm to break. Does anyone know if you can program the warm stop using VCDS? I have got the data off of VCDS, but could not see a way of programming it. Is the actuator controlled via the temperature controller and could this be throwing it out. Any advice on VCDS would be appreciated.VCDS 1.jpgVCDS 2.jpgVCDS 3.jpg
My right hand actuator is going past its warm stop and causing the arm to break. Does anyone know if you can program the warm stop using VCDS? I have got the data off of VCDS, but could not see a way of programming it. Is the actuator controlled via the temperature controller and could this be throwing it out. Any advice on VCDS would be appreciated.View attachment 106969View attachment 106970View attachment 106971
The VCDS experts can be found on the T6 Forum.
