Hi, please would you update the thread with your progress? Many thanks, Mark.
Hi Mark, update as promised. This is my Phase2
Firstly, a big thank you to all that have made suggestions to me on this thread and to those that have posted on the subject here on this forum as well as the T6 forum. All really helpful to me.
Well I have just finished the instal of the Victron DC-DC unit under the passenger seat. A bit of a shoe horn needed as the photos will show. one thing that stood out in my research was that many said the Victron runs pretty hot. Not ideal for a small enclosure.
I overcame this by making a mounting plate and angle support out of Alloy and mounting the charger to this using plenty of thermal conductor paste to help transfer any localised heat.
Main consideration was to allow enough space at the lower end for air to flow through the sink to the alloy.
Another consideration was to keep all vw cables and assemblies untouched so that all original components can go back Should I wish in the future.
All additional wiring is 16mm2.
I have more or less followed Loz’s instructions and setup using an insulated post and additional fuse holder. Instructions on battery disconnect sequence etc followed to a ’T’ (thank you Loz)
I have done a little testing after hammering the batteries (diesel heater & fridge on full for a while). As photos show it charges full, greater than 20amp charge on CP display. Little or no heat felt on the charger or heat sink. Will do more monitoring and mount a temp probe on the sink to monitor for a while.
I have set battery type to spiral agm On charger, also I have left the little plug in link located under charger. I hope this is correct.
I am not 100% sure on the other settings in the Victron App, I think I have a smart Alternator so set that.
If anyone could help me out with photos of correct or best settings for the AGM batts, or advise it would be useful. Ta.
I will include some pics of my current settings when next in camper.
Again, i have read so many posts on this subject so a big thank you to all, without that knowledge from so many, I could never have started this project.
Phase 3 will be the lifePo4 upgrade on the leisure’s.
