N
Great read well done I spent years rebuilding a land rover defender nothing more rewarding than bringing a vehicle back to life and you get to know exactly how things work keep the updates coming.Day1 of clutch & flywheel change, steering rack & arb disconnected from subframe and held up to engine with zipties. Lower balljoints off hubs, driveshafts out. Both balljoints need replacing as boots are drying out with age. Balljoint tapers stuck in lower arms. Front & rear Engine mounts disconnected from subframe, subframe bolts out one at a time and alignment pins fitted to chassis. Subframe out, damn thats heavy. Lower balljoints knocked out with subframe inverted and supported. Engine to gbox bolts all loosened. Damn starter motor is a pain, cant see the upper bolt - job for tomorrow. Gear linkage disconnected and mechanism free of gbox. Engine crane in place. Just need the starter off and hydraulic line off the slave. Hopefully get these off and then the box out. Looking like 3weekends and ill be done. Anyone doing similar pretty much all mounting bolts / nuts are single use thus £140 to the bill.
I like how organised and tidy your garage isDay1 of clutch & flywheel change, steering rack & arb disconnected from subframe and held up to engine with zipties. Lower balljoints off hubs, driveshafts out. Both balljoints need replacing as boots are drying out with age. Balljoint tapers stuck in lower arms. Front & rear Engine mounts disconnected from subframe, subframe bolts out one at a time and alignment pins fitted to chassis. Subframe out, damn thats heavy. Lower balljoints knocked out with subframe inverted and supported. Engine to gbox bolts all loosened. Damn starter motor is a pain, cant see the upper bolt - job for tomorrow. Gear linkage disconnected and mechanism free of gbox. Engine crane in place. Just need the starter off and hydraulic line off the slave. Hopefully get these off and then the box out. Looking like 3weekends and ill be done. Anyone doing similar pretty much all mounting bolts / nuts are single use thus £140 to the bill.
Good job, did mine last year, don't forget to clean the roof drain hole grommets and then wipe them with a little silicone sprayWipers and scuttle panel off to clean out the moss and leaf litter collection.
Hi Nik, we to have a 2010 Cali SE, 140, done a very similar thing to you and gone through entire van mechanicals. We have done some mods with the rear sliding seat and created a fold out rear bed board that clips into the original Cali rear brackets and head rest fixings. My goal was to create more living space in the day, bench seat now slides back, base cushion level with cup holder (which can now be used inc 12 volt plug) so created an extra 40cm in the day and 20cm at night. Created a fixed / removable slide out toilet on heavy duty runners that can be used when bed is fully out. This is a game changer and one of the most ambitious projects I have under taken.
Not sure if it’s the first California to have a fixed slide out toilet! Also have a drop down curtain that is shut away behind folding roof shutter, this can be deployed at night when stealth camping to shut off cabin area.
Moving the bench seat back so it’s now over the rear wheels has improved handling no end.
I also fitted genuine VW T32 front and rear suspension springs to improve and stiffen handling
from the current T28 set up.
Metal ironing / bed board removed. Why VW thought that was a good idea is beyond me. I appreciate storage is vast under there, but you only fill it with crap you don’t really need… I still have loads of storage but most importantly more room in the main living area with better access to wardrobe…
Many thanks for sharing your hard work and it’s nice to see a fellow owner that’s prepared to put in the effort and rebuild etc… So many owners tend to buy nearly or brand new, yet there are so many used examples out there that will do exactly the same for a lot less money. We bought ours and paid for it out right, so it’s paid for, none of this PCP garbage! Yes we could of bought a brand new one, but why spend £65000.00 when you can pick one up used for £32000.00?
I’ve done loads more mods, internal bike rack that locks into floor rails, we can get two full size MTB,s inside, fork mounted, due to the extra living area space created.
Good luck with your future endeavours!
You have now inspired me to do similar! great work on your TLC projectScrape through the cupboard door finish blended in with some enamel model paint. 10mins work and £9.99. Its the small stuff like this that collectively make a difference.
Thorough job! looks lovelyDriveshaft back in, full service and 50miles to confirm the cooling system holds pressure. Replaced the chinese headunit with a kenwood DMX8020DABS sound much improved, great DAB reception and wireless android auto great too. Washed and ready for a fresh MOT on friday.
Next year ill do the cambelt and replace the exhaust with a standard layout but in stainless.
All in renovations came to £4k making full cost £35k which im happy with knowing its full serviced and ready for years of camping use.
Touched up the step lights with silver paint and repainted the red i tailgate badge. All 3 of the step light housings are cracked but didn't realise until i came to touch up the paint, at £40 each they won't be getting replaced.
Silver paint pen from amazon, nothing fancy not perfect colour/metallic match but improves them no end, aint no way im spending £130-£150 on 3 new lights.What paint did you use for the foot light?
