Philfox3
Good morning
A pair of Isabella ‘Freja’ chairs. As new.
Collection from LL31 ( DEGANWY North Wales ) as they’re probably going to be expensive to post.
They’re a bit heavy for me but otherwise very well made and comfortable and fit sideways across the rear shelf of a Cali.
Thanks for looking.
Phil
The Isabella Dark Grey Freja Recliner Relaxer Chair is a comfortable and ergonomic armchair designed to provide maximum relaxation for the user. This chair is perfect for use on holiday, at home, or in the garden.
The chair has an infinite number of reclining positions, which means you can adjust it to any position that suits you. This feature allows you to sit back and relax with ease, and the chair can be fully reclined so that you can lie back and rest your entire body.
The chair is designed with ergonomics in mind and is constructed with a steel frame that provides stability and support. The frame is strong and durable, which ensures that the chair can withstand regular use without losing its shape or stability.
The fabric of the Isabella Dark Grey Freja Recliner Relaxer Chair is made from 100% polyester, which is soft, comfortable, and easy to clean. This means that the chair is resistant to stains, spills, and general wear and tear, making it a long-lasting and low-maintenance option for relaxation.
The Freja armchair is also designed to be easy to transport and store. It folds up from both sides, which means it takes up very little space when folded. This feature makes it ideal for travel, camping, and outdoor activities, as well as for use in small living spaces.
Overall, the Isabella Dark Grey Freja Recliner Relaxer Chair is a high-quality and comfortable chair that offers maximum relaxation and support. Its ergonomic design, infinite number of positions, and durable construction make it an excellent choice for anyone looking for a reliable and comfortable armchair.
Specifications
Thanks for looking.
Specifications
- Load Kg: 120
- Width (cm): 66
- Depth (cm): 94
- Height (cm): 119
- Size Folded: 30 x 107 x 19 cm
- Net Weight: 10
- Height of backrest (cm): 80
- Seat height (cm): 54
- Seat width (cm): 55
- Seat depth (cm): 51
