Standard. Has been for a while.VW California Ocean 2023 Auto Hold Function - is this an available option?
Hi, I am not talking about Hill Hold, but rather the Auto Hold button for when on a flat road standing at a traffic light for instance.Standard. Has been for a while.
Explains why Mercedes are always slow off the mark.There is as standard a delay on releasing the brakes of about 3 seconds when doing a hill start.
There isn't anything like Mercedes have with their hold function whereby you can press the brakes a bit harder whilst stationary & it keeps them on until either the brake pedal or accelerator is pressed again.
Don't know about the latest but on our July 22 MY21 6.1, no, it was not an option. You have to keep your foot on the brake, unlike our Tiguan. All linked, one assumes, to the 6.1 underpinnings and the manual handbrake.Hi, I am not talking about Hill Hold, but rather the Auto Hold button for when on a flat road standing at a traffic light for instance.
Explains why all the brake lights are on when in a queue of traffic, they stay on even with your foot off the brake.Explains why Mercedes are always slow off the mark.![]()
Thanks for the confirmation, this is what i thought, due to the manual hand brake.Don't know about the latest but on our July 22 MY21 6.1, no, it was not an option. You have to keep your foot on the brake, unlike our Tiguan. All linked, one assumes, to the 6.1 underpinnings and the manual handbrake.
I have a 73 plate Ocean. Was a little perplexed today as 2 instances I was expecting the hill hold to operate (like on my mini).Thanks for the confirmation, this is what i thought, due to the manual hand brake.
AFAIK there is no hill hold on a Cali (towing pack?). So, to be expected and how ours works.I have a 73 plate Ocean. Was a little perplexed today as 2 instances I was expecting the hill hold to operate (like on my mini).
1) Parked downhill, place into reverse, foot on brake, release handbrake van stats to roll forward !!
2) Coming up to a junction on an incline, slow with brake to standstill, release brake van starts to roll backwards !!
... I need to go and out and test some more. OR is this to be expected?
(my mini always holds the brake on for 2-3 seconds in time for me to depress the clutch, engage a gear and slip the clutch)
Thanks. I have a towbar (but no trailer assist)?AFAIK there is no hill hold on a Cali (towing pack?). So, to be expected and how ours works.
Just read the manual - 'Hill Start Assist' is a function of the van apparently.AFAIK there is no hill hold on a Cali (towing pack?). So, to be expected and how ours works.
Not on our MY22, so assume it's part of a pack somewhere.Just read the manual - 'Hill Start Assist' is a function of the van apparently.
..im off to find a hill![]()
ahh that sounds promising. Will tryYou need to press the brake a bit harder when you stop. It should hold the same as your mini.
As the system just delays the release of the brakes it won't work if you havn't pressed the pedal hard enough in the first place.
Ok - so on Andy's poking checked and we DO have Hill Start. Found it in the manual and it is the following (as most are auto just put these in). Never noticed it to be honest, but never knew either.It was standard on my 2014 T5.1 & has been on every van I've had since, if you look under standard equipment on the configurator its showing there.
