Hei, i år drar vi endelig til England. Og en av de tingene jeg er bekymret for, er for sønnen min. Han slutter ikke å vokse, og sengen over førerhuset er for liten. Er det noen som har den magiske løsningen for å utvide sengen?
Up to 190 cm long.
Wow, that's brilliantly made! Smart stuff @Sven Ole! Our is a T5.1 and not a Grand California, but I love to see these kinds of DIY-solutions.Up to 190 cm long.
Has been tested and works fine. Too pillowy. Can be removed from above. Made of wood.Thank you Sven. It's ingenious, it rests on the ladder, doesn't it? Is it made with wood?
I didn't find the length or width of the top bed in a GC600 a problem, it was the head height, I constantly turn over in the night & I had to position myself under the roof light to have enough room height to fit my shoulders. The other thing that I didnt like was if I pulled the duvet up to far, there wasn't anyway I could get it back down the bed to cover my feet.My teenage son is over six foot tall and sleeps quite happily, diagonally across the bed, foot at the extension corner, head at the sliding door side, using a sleeping bag and pillow.
Remove and place it on the mattress after use. Take it with you if necessary. No weight 4mm veneer. No changes to the original vw construction. My family is 30 year and 188 cm slip good.When looking in to this myself I was quite surprised that there doesn’t seem to be an off the shelf bed extension solution from one of the accessory providers. How easy is it to store Sven? I wondered if you might be able to put a hinge in it somewhere so it can fold when not in use.
You should start selling them on Etsy or something, 50o Nord charge €183 for some boxesRemove and place it on the mattress after use. Take it with you if necessary. No weight 4mm veneer. No changes to the original vw construction. My family is 30 year and 188 cm slip good.
Well you've just got us considering switching to a Grand again. DAMN IT AND YOUR INGENUITY!
Would not have bought the Grand without this option.Well you've just got us considering switching to a Grand again. DAMN IT AND YOUR INGENUITY!
The board is put on and removed from the upper bunk after the ladder has been used or is to be used without problems.Make a cardboard template for the desired size. The board is put in place when the guest is in the bunk. Skylight creates extra ceiling height when the blinds are off. The board is lifted away so that the ladder can be used from the bunk, good morning. The two legs are hinged. Good luck.
What you can do, on right hand drive models, is remove the table, turn the passenger seat, tilt the seat back, fill in the gap where the table was with suitcases, cushions etc to the hight of the bench, and then sleep there. As an overweight pensioner, slightly above average height, with a bad back, it's worked for me!
