CannonDale
Sika flex or CT1 would sort that.Thank you! I will give it a go after I do several water tests with garage’s sealant fix.
Do you know anything about roof corrosion? What this could be and what issues this could cause.
I’m just trying to trace this leakage. It’s coming from different location now. However, the car is parked on the slope, front left at the lowest point and is difficult to say where the water is coming from.
I’m thinking about removing a headliner to see what’s happening there. Any instructions how to remove it next to the control unit and around the sliding panel above the head?
Thanks, Jev
