Size. If you are so inclined to lose cupboard space it can go in there. Ours fits in the SpaceMate perfectly. You can also put a Dunelm box over it if you want to pretend you have no bodily functions. Or piddle into a bottle. I go without fail at 3am so have no issues carrying one rather than stumble around a campsite to the loos. Sits in the boot or chuck into our pop up festival tent through the day.Looking for a cassette toilet and can't understand the difference between the various Thetford models. Can anyone shed any light please? I know the 335 seems to be the favourite but what's the reason v other cheaper models?
The Thetford website doesn't give dimensions or the full range, hence why I asked the questionSize And pimp type, check out Thetford site they provide details of their products.
Thetford - Porta Potti - Portable Toilets
Discover our range of lightweight, comfortable and easy to use camping toilets for your next travel adventurewww.thetford-europe.com
I've finally found the spec sheets!!The Thetford website doesn't give dimensions or the full range, hence why I asked the question
That’s the wrong type !Size And pimp type
Unless you plan to use the thing while the van is hurtling around twisty B-roads I'm not really sure whey you'd need to secure the Thetford to the floor. We've had one for years and while it usually lives under the rear shelf, we've often had it in the main body of the van while on the move and it hasn't been prone to sliding about. If it did, I guess I'd be inclined just to glue a couple of foam rubber strips to the underside, rather than spending a lot of money on Teutonic hardware.Does anyone in the UK produce a bracket to secure the 335 to the floor rails? Seems to be some in Germany but seems a lot of money for what it is.....especially after shipping.
That's good to hear.Unless you plan to use the thing while the van is hurtling around twisty B-roads I'm not really sure whey you'd need to secure the Thetford to the floor. We've had one for years and while it usually lives under the rear shelf, we've often had it in the main body of the van while on the move and it hasn't been prone to sliding about. If it did, I guess I'd be inclined just to glue a couple of foam rubber strips to the underside, rather than spending a lot of money on Teutonic hardware.
Each to their own, of course.
Our 335 sits under a Dunelm Ottoman and when travelling is secured by a bungee to the drivers seat.That's good to hear.
I've not got one yet but the thought of it flying about while I was driving was the bit that put me off.
Might still put a bungee around it to help my anxiety though![]()
Perfect - that's exactly what I had in mind. The bungee with the quick release clip is a great idea tooOur 335 sits under a Dunelm Ottoman and when travelling is secured by a bungee to the drivers seat.
Note, you put the Ottoman upside down so it just lifts off.Perfect - that's exactly what I had in mind. The bungee with the quick release clip is a great idea too![]()
Same here as others have said , Dunhelm box over the top . Ours has never moved , mainly due to the water it holds for flushing . I think that stabilises it .Does anyone in the UK produce a bracket to secure the 335 to the floor rails? Seems to be some in Germany but seems a lot of money for what it is.....especially after shipping.
Mine came from Thetford with some brackets to screw to the floor. But we don’t need them, it sits behind the drivers seat and does not move
As Velmas dad says it will be fine nothing will fly about it’s very secure just on its ownThat's good to hear.
Totally agree. Wouldn’t be without ours. In exactly the same place as yours. No hassle.Are we the only ones who keep it in the cupboard below the sink, when not in use, to be brought out at bed-time when "downstairs" becomes the bathroom? That's why we bought this model (thanks to this forum); it fits perfectly. The seals are still really good after more than 10 years - hygienic, no smells and no likely possibility of leakage. Rarely used for more than peeing and never allowed to become over-full, but we wouldn't wish to be without it!
We went for the 345 which is a bit bigger for my derrière. It fits neatly in the back of the van although I can see the benefit of the 335 taking up less space. On reflection we are happy with our choice and would definitely recommend having one whatever the modelLooking for a cassette toilet and can't understand the difference between the various Thetford models. Can anyone shed any light please? I know the 335 seems to be the favourite but what's the reason v other cheaper models?
