Thank you for responding. This was bought 2nd hand on ebay and the pegs and these straps were missing. I will contact Vango directly then. I better not buy the wrong type."8m Webbing straps
If you don't have an attachment point on your vehicle, don't panic as storm webbing straps can be used! The webbing straps are supplied with the awning and can be clipped into the buckles on the rear of the Air Away roof. The straps can then be passed over the roof of the vehicle and pegged into the ground. It is also important to adjust the straps to fully tension the roof."
How does a Vango Drive Away Awning attach to my van? - Vango Blog
How to attach a Vango inflatable awning to your van?www.vango.co.uk
No, I would like it on the slide opening door side, AND also retain the wind down awning, as the Vango is to be used for longer stays on sites.Use the channel on the non door side?
Thank you for the link which opens up to the Vango page. Much appreciated.Thank you for responding. This was bought 2nd hand on ebay and the pegs and these straps were missing. I will contact Vango directly then. I better not buy the wrong type.
Good point. The roof would need to be down to use the straps. I may be 'forced' to remove the wind down awning.There is a channel on the front of the wind out awning that you can attach the drive away to I don’t think over the top straps will work with a pop top
Then another option is to wind out the awning, attach the tent to it and buy the side panels for the wind out awning to create a further zone. When going out for the day just remove these, slip out the kador and wind in the awning, leaving the tent where it is. Mark your wheels (we use tent pegs) to make it easier to realign when back on site. Using the up and over straps and not being able to put the pop top up will, imho, be unworkable and a faff in the long run.No, I would like it on the slide opening door side, AND also retain the wind down awning, as the Vango is to be used for longer stays on sites.
