It should be repairable if you still have the broken bits; I had to fix mine years ago. The plastic of the hinge will bond to Araldite or similar epoxy resin.Thanks for the tip, I’m exploring a repair option on the table, but will be treating it gently in the meantime
For the metal hinge, all fitting details are supplied.Hi Nippy, Thanks for the reply..... In case I need similar, how did you fix the new hinge to your table?
There doesn't seem to be much for screws to get a purchase.
…and morning again!Morning Doorbundle, thanks for taking the time to write, and apologies for the late reply, just back from France…
I did in fact buy one of these hinges and fitted it before we set off, it was a bit of a fiddle, but works well, it’s not quite as robust as the alloy alternative, but would seem more than adequate for the job.
Next job, wind out awning, splitting down the seam with the heat!
