Put it on before deploying the awning?How do you get the drivers side one on if youve got the awning out?
Our Jan 24 Ocean has only experienced sacking once this summer and it was very hot and only to the point the fabric wasn’t as taught as normal, so only a minor issue. Any other use has been fine so I feel this is acceptable and is mentioned in handbook. I’m also happy to report no leaks from the 06S roof in a heavy downpour thunder stormThere's lot's of posts on this one and a long one I created some time ago.
https://vwcaliforniaclub.com/thread...ng-bellows-roof-poptop-tpi.56210/#post-728126
Ours still sag too much for my liking and am thinking about having a new Hydraulic pump fitted. Apparently there is a new version of the pump in production now (I don't know when it hit production) but I'm keen to hear peoples experiences. It is rumoured there was a bad batch in late 2022 into 2023 so I'm keen to understand if any folks have the problem with T6.1s manufactured in 2024 or indeed T7s. I'm guessing they use the same pump, but only a guess.
It’s the temperature change that causes it.Is it just hot weather that causes this?
We had 10 days in Austria last Christmas, warmest temp all trip was -5, coldest -13.
Roof sagged slightly after three days.
We get this too. I just resort to lowering the roof to the first stop (is the bed down prompt etc) and then press the open button. It's annoying, but not the end of the world. Your explanation helps me accept this. Thanks.It’s the temperature change that causes it.
At the higher temperature the hydraulic fluid expands the pressure goes up as the hydraulic rams containing the fluid don’t expand so much and so the excess pressure bleeds through a pressure relief valve. When the temperature drops the fluid contracts and the pressure drops so the rams will drop . That’s why the pump is supposed to re-pressurise the system at regular intervals once the pressure has dropped sufficiently.
Normally this occurs 10 hrs after Ignition off with roof up and thereafter on a regular basis only if there is sufficient pressure drop.
I suspect there’s a caveat to this condition?That’s why the pump is supposed to re-pressurise the system at regular intervals once the pressure has dropped sufficiently.
We have a March 24 van and definitely experience this, previously owned a 2019 and had no issue like this, the 2019 once dropped slightly after a week but automatically corrected the 24 plate doesn’t auto correct we have to do it by lowering a bit then raising.There's lot's of posts on this one and a long one I created some time ago.
We have a June 2022 Ocean. After 3 days of warm weather the pop top sags & slightly more on the drivers side. Ignition on and select raise pop top again and it resolves the slight sag. Annoying. Haven’t ever taken it to VW to be checked though. Interested to know how people get on with dealers.There's lot's of posts on this one and a long one I created some time ago.
Perfect weather to test the fix!!!
The 10 hour re-pump is a bit temperamental. If you open the roof from closed at hour zero it will check at hour 10. If you manually raise the roof before 10 hours that definitely messes up the timer and it never checks again. I have a suspicion that turning on the ignition could also mess up the timer...
So the saga continued for us.Testing the roof up today in 25 degs plus. Looked fine from the outside but when I got in, found we had sag on the passenger side
Will drop and test again tomorrow when we are forecast 30 degs so should sag quicker!! Then we are back to my favourite garage in Southampton if it doesn't behave itself.
Some decent weather to check it next week. Good result getting the pump replaced. May I ask how much it was sagging?So the saga continued for us.
We had the hydraulics bled 3 times and hoped the sag issue had gone away. However, we had a sag on the passenger side.
The workshop manager at Breeze, Southampton suggested I lowered and raised the roof twice which resulted in the roof sagging more equally on both sides so it went back this week for a roof test.
That resulted in the hydraulic pump being replaced.
I hope that concludes our issues, testing next week so will find out!
Ocean, 2024
Shout out to VW Breeze, Southampton who have been great.
This was the sag after 5 hours at 25 deg C and after it had been bled three times. I didn't measure it unfortunately but it was clearly in its way down.
