GC600 Locker 3D Scan
Thats great, thank you for sharing. What did you use to do the scan (I’ve tiried Polycam on a number of occasions and parts with little success)
I had to use about 50 tracking markers, difficult scan with not much texture to track.
Work continues on better pants and socks storage.
Bambu H2S with a 0.8 high flow nozzle, print wasn't perfect but not too far off so will make some tweeks.
Bed can go up to 340x340mm but for the locker 2 boxes at 270mm wide is about right.
Seems to be about 5hrs per box currently. Also used some PETG support interface for the overhang.
That print was a wall thickness of 3mm, will drop it to 2mm as it was plenty strong, should also be able to get 2 out of a spool then as well.
my limit is print bed size as only 220mm but if you are happy to share 3d file I could try to do 3 boxes for wider cupboard.
Yes of course, have made some tweeks and think I have it printing well now, will make a version for 3 per locker.
Why does this forum keep dropping pictures in posts and making them links instead, really annoying!!
Just to note this was all based on GC600, unsure if the lockers on the GC680 are the same.
that’s great thanks for this will have play, mine is 680 so will check sizing
