jonclareVWGrand
I know others have been confused with the additional heater options that come with the diesel heating.
From a google search I found a van converters manual, and think I now understand what each heater option is (or at least think I can explain it to myself) so this may help others too.
The manual is here. https://bb-database.com/jctumbau/do...2017.pdf/8affbc51-3dd9-4ece-9192-faee81c2ff1d
I think the two options (7VL and 9M5) are both 5kW driving cabin heaters that are diesel powered. They heat the coolant water before the engine heats up, so that the blowers start pumping out heat much faster from a cold start.
The more expensive one has the remote and control panel, so i guess the cheaper one just comes on when you start the engine and it is cold.
I can’t see much logic as to why you are forced to take one or the other with the diesel combi boiler.
In my prior diesel Audi I seem to remember an extra heater to heat up the car quicker as the diesel engine takes longer to heat from cold. My replacement petrol Audi (same model) heats up much quicker than the diesel one did.
Screenshots of the relevant pages are attached. Hope this helps others.
Jon
Jon
