230V B pillar not working anymore red light
Silvano
Nederland
T6 Ocean 204 4Motion
My outlet isnt working anymore on the B pillar it was working just fine, its constant red now.
Been looking on the forums but couldnt find it.
Dont know what fuse i could look for but the ones under the front seat are looking fine.
Help pleaseeee :)
Help pleaseeee :)
As a VIP member you can access the Fuse charts in the Resources Section. They might be helpful.
The fact that you have a red light On, normally means power is OK but there is a fault.
Will take a look in to that, but until now no blown fuses .
it goes red if the leisure batteries are low. what happens on hook up or engine running ?
I didn't have time to look yet, but I am now working on it and no longer have a red light at all.
The voltage is more than sufficient and shows 100% on the indoor unit.
I also did something stupid, I thought you could click out the outlet, but now the plate lugs are broken off, does anyone know where you can order these?
And do you think the B pillar has to be removed to get to the inverter?
Hopefully someone knows a solution...
It has been a while, but I have now found the time to investigate further.
The 230v inverter flashed green/red and the fuse was sometimes blown and there was no more power from the socket.
I then removed the B pillar, first the top, which is clamped and not secured with clips. The bottom part is secured with a number of clips. It is doable in itself.
When everything was off I could clearly see the 230v inverter, which is mounted on the side of the kitchen cabinet on the inside with 4x m6 bolts.
The problem quickly became clear when I opened the 230v inverter, it seemed oxidized, perhaps water entered through the side window??
I then bought a model on Marktplaats, which differed in terms of coding, but seemed the same, but did not work. Maybe it has to do with another chip that communicates with the odb system.
Afterwards ordered from a car parts store for about 250 euros.
Built-in and working perfectly again.
I will also add some photos so that the next person has more information about what to expect.
Greetings Silvano
Raggedroy
Raggedroy
drmanhattan
calikev
calikev
H
ejmoore
California Dreamer
California Dreamer
