You could charge the rear battery, but with a voltage differential of 0.43v there shouldn’t be a problem.Sorry to hear this @Coasterman. It look like I have likely the same issue on a coast that is 4 weeks old. I have been away for the last couple of weeks and pretty disappointed with the battery life (2 days or so down to 12.3v with the fridge set to 3 and not really using anything else). I did notice at full charge the voltage of the front battery measured 12.9 or so but the control panel itself was only showing 12.6/12.7 when fully charged so this may be a pointer to the issue.
This thread prompted me to get into the rear battery and I am seeing 12.78v above the cube fuse (front battery probably not quite fully charged) and 12.35v below. I managed to get the battery out and the fuse is blown - probably has been since I collected it I guess. Local VW centre cant look at it for a couple of weeks so I am going to just buy fuse from them and give it a shot as planning to go away again next week. Couple of questions if I may hijack your thread since all the infos here.
I was going to recharge the battery as you suggest @yossarian to reduce the differential a bit. Positive from front battery is removed and taped up. Should I charge via the other side of the shunt to include the battery monitor or directly on the battery itself? and do I need to disconnect the 2 pin connector to get it to recalibrate afterwards? Worried about upsetting the control panel..
Also I am not the best at gauging tightness so any advise on how tight to make the positive when I get the new cube fuse and reconnect front battery as understand they are easy to crush?
If you do recharge connect the -tve to a chassis earth, battery clamp bolt, or downstream of the shunt.
Could take 4 hrs or so for the battery monitor to recalibrate.
With regards tightening up the +tve lead I normally hand tighten then 1/4 turn with spanner.
