stew
Hi,
Due to a nail in a front tyre which couldn't be repaired, I've replaced both fronts with new Sport 01s. The rear has the original Sport 01s with about 4.5mm left on them, so time to replace soon, but not necessary right now.
Since I had the new tyres on, I've noticed a distinct but subtle 'throbbing' noise when the drivetrain is under load, especially around 30-50mph.
I'm wondering if it's something to do with the 4Motion differential acting strangely because of the new/old tyres. I checked the manual and there is no recommendation to switch all 4 tyres at once, it only says that tyres on the same axle should replaced as a pair and that all 4 should be the same size/width/type/tread pattern etc.
I was thinking that as the old, rear tyres have a smaller diameter than the fronts, they will rotate faster and perhaps the diff is trying to push power to them as it thinks they are 'spinning', hence a noise I haven't noticed before and perhaps more wear on the diff?
Does anyone know what the explanation could be?
Thanks,
Stu
Thanks,
Stu
