2into1
Née T4WFA. Now without Cali :(
I’ve a query for those of us running (or previously owned) a pre-facelift T5 with the 5 cylinder engines. Both 130hp and 174 versions.
I’m struggling to get rid of engine / exhaust smell, despite having attended to many of the causes particularly known for this engine. Several folk I’ve spoken to just tell me these engine are notoriously ‘smelly’ so I don’t want to waste more time and money if that’s the case.
I know many of them suffer with cracked / twisted exhaust manifolds so we changed that for a new vw part and did all the associated gaskets. The smell was still there (it’s in the cabin but also all around the perimeter of the van) so we used a smoke machine shoved in the turbo outlet pipe, pumping smoke through the engine, and found several small leaks on the dpf clamps (both sides). You could feel a draft from the small egr pipe so we put new gaskets on that.
The only leak we can now see is a tiny whisper from the turbo actuator but apparently that’s normal (as it’s a bearing surface) and I can’t believe that’s anywhere near enough to cause the smell.
The smell is there almost instantly on start up, and I seem to get a second wave inside the cab as the water comes up to Temperature. I’ve no headache symptoms so don’t know if I’m dealing with exhaust gas or just a smell.
It runs just fine. Doesn’t use oil or water. I’ve found random posts on other forums saying they’ve got rid of similar smells with changing moo valves / mafs or dealt with injector problems. The engine has no codes other than a recent (the smell predates) glowplug low voltage warning on cylinder 2.
So, I’d welcome any general thoughts from owners plus any tips on my own situation. Cheers.
