50mpg
mickmull
UK
Had a run through the North York Moors of around 90 minutes and nursed the gearbox of our California (150hp manual) in variable traffic but mostly in the 40- 60mph zone, certainly not hanging about - and managed to return of over 50mpg on the computer - Ok I know that the computers are not perfect at fuel consumption but they do give a guideline. Didn't hold up any traffic either...
So
lets have some mpg stories!
I definitely get some :pinkbanana
118.6mpg for the last 4500miles since its service last December (buggers always reset the history) or 66.8mpg for the first 5122miles on the CHR (drove it tonight as I had to fill it up) . To compensate the V8 being doing about 17mpg.
100 mpg ? Outstanding - always thought that the MPG thing was linked to the ECU running the engine - but I guess it may be estimate!
Can't do 50 mpg. Over 20,000 miles have averaged 37mpg. Best ever on one tank was 43. T6, LWB 150 DSG.
Not charging all the time and a few trips to London dropped the average down. Does about 40-42mpg on a flat battery. Not my car but a stock photo. (Not a car you are really too bother to photograph)
Fully loaded up inc full tank of water and fuel plus 3bikes on the bike rack 38.1 mpg will definitely miss this when we get our crafter/Man Westfalia
Four times I have managed over 40 mpg on brim to brim measurements recorded on the "Road trip" app.
Refill 13 March 2018: 1009 Km, 71.16 Litres, 40.05 mpg, fully laden with four bikes on back
Two refills 13/16 April 2018: total 1422 Km, 99.01 Litres, 40.57 mpg, fully laden plus four bikes
Refill 28 June 2018: 1062 Km, 74.12 Litres, 40.47 mpg.
Refill 26 November 2018: 1083 km, 73.39 Litres, 41.69 mpg.
My record on the MFD on 11 January 2018, before I started using the "road trip" app to record fuel consumption, was 18.2 km/l which equals 51.4 mpg over a single 638 km run about half on Sicily's empty motorways.
The brim to brim measurement was 16.43 Km/l or 46.4 mpg.
Think our overall average is around 38 - 40 mpg - just had a good run yesterday. Just shows you how frugal these things can be on the right road and speed combination. Going to have to try not to become addicted to watching the av consumption read out...
Ours consistently did around 36 ish..Tank full to full not computer. have just had it remapped and done around 800 miles some motorway some town and now get 41.Full to full...also less gear changes.Cant see how I could possibly get any better driving like a vicar...
The MFD consistently overreads when compared to brim-to-brim measurements.
Think either way has its issues... Not sure how accurate a pump is and I tend not to check the ambient temperature that my fuel is delivered at from the pump!
Thought the MFD feature was a by-product of fuel injection computers, so rather than measuring your tank and how many miles, they count the duration and number of injection pulses, hence fuel being used. That's why you can get a 'range' feature too. My MKII Golf GTI had that on. Guess if MFD mileage is wildly out may point to an injection or fueling issue... Someone on here will know how it works.
The MFD won't take account of diesel usage in the Parking Heater or the Webasto Engine Coolant Heater.
Good point there WelshGas! The MFD will read diesel going into the engine and miles covered. If you do a 'tank to tank' check and run the diesel heater all night then it may seem you are getting poor MPG!
I have 30 months of detailed consumption both from the MFD and brim-to-brim. The MFD nearly always overreads MPG.
Datebrim to brimMFD
4 Sept 2033.3934.7+3.9%
19 Aug 2039.1838.1-2.8%
8 Aug 2033.735.1+4.2%
18 Jul 2033.1235+5.7%
3 Jul 2032.3532.9+1.7%
14 Jun 2035.3737.5+6%
26 May 2036.0738.1+5.2%
9 May 2033.8436.7+8.6%
14 Mar 2032.1734.3+6.6%
21 Feb 2034.3335.4+3.1%
18 Feb 2036.8938.0+3%
1 Feb 2033.1436.4+9.8%
2 Jan 2030.132.9+9.3%
7 Dec 1937.9239.9+5.2%
19 Nov 1932.1234.4+7.1%
21 Oct 1934.24No record
22 Sept 1935.0638.1+8.7%
31 Aug 1935.136.7+4.6%
20 Aug 1931.0432.5+4.9%
16 Aug 1937.1538.9+4.7%
4 Aug 1930.5633.2+8.6%
18 Jul 1928.2531.1+10.1%
25 Jun 1928.0730.9+10.1%
12 Jun 1934.836.8+5.7%
1 Jun 1936.2337.9+4.6%
25 May 1930.2631.1+2.8%
23 May 1929.2229.4+0.6%
16 May 1927.8731.8+14.1%
16 Apr 1933.2337.1+11.5%
5 Apr 1926.1129.4+12.6%
16 Mar 1935.8440.5+13%
Notes:
  1. The overreading of the MFD does appear to be worse in winter months when the heaters are being used. Evidence of this is weak.
  2. In July 2019 we bought a city car as a second car. This is predominantly used for short trips. The overreading in the MFD was far worse when Amarillo was our only vehicle. Further supporting this hypothesis is that during late May and Early June 2019 when the MFD appears comparatively accurate Amarillo went on a return trip to northern Spain. Evidence of increased accuracy for longer journeys is reasonably strong.
Crumbs Amarillo! That's a detailed record.
Looking through I would expect the MFD to 'over read' when using the heater. Your figures will give you a lower tank to tank mileage if some of the diesel is being used to keep you toasty - whereas the MFD should be reading what goes into the engine for the miles you've done.
I guess not all the energy from the combustion of diesel in the engine goes to pushing you down the road, and in winter more is used for auxiliaries plus engine oil takes longer to warm up and all that sort of thing. Short journeys are not very efficient in any car I don't think.
Guess on a longer run the batteries are charged, the engine warm, and in northern Spain you may not have the heated seats running!
Think I may switch mine to show what radio station is playing and not worry about the mpg!
Often the first evidence that something is wrong with the engine.
There is a difference between Observing and Obsession with regards to MPG.
As long as mine is in the ballpark I just drive and fill.
With modern vehicles I'd pay much more attention to the ECU microprocessor and any warnings it throws from its million+ lines of code continuously analysing dozens of sensors including:
- Fuel flow
- Air mass flow
- Manifold pressure
- Intake air temp
- Oxygen level
- Throttle position
- Crankshaft speed
- Whether car is connected to an emissions test rig (VW special option).
And with older cars... well all I can say is in 40+ years I've never detected a fault by monitoring fuel consumption and spotting any changes. Clattering noises from the front, smoke in the real view mirror, pool of oil spreading gently over the road, yes. ;)
I use an app called “Road trip”. All I do is tap in the odometer, refuel and MFD(2) numbers and the app does the rest.
