![Ozzy Pete](/data/avatars/m/28/28529.jpg?1646510659)
Ozzy Pete
Just wondering if anyone knows where the ABS fuse is in 2015 SE. I’ve looked all over the Web an can’t find anything. Any help would be appreciated.
Fuse 5, 50amp fuse in Fuse Box A which is situated on Passenger side of engine compartment by the engine battery.Just wondering if anyone knows where the ABS fuse is in 2015 SE. I’ve looked all over the Web an can’t find anything. Any help would be appreciated.
Would this have ABS on it. Or is this the universal sign for Brakes. As in Handbrake? And what size is this fuse?Do you have this fuse box layout. If so fuse 9?
Have you looked at my post above.I’ve just had a look in the top bank of fuses in the cab passenger side and there isn’t a fuse 9. There’s no provision for a fuse. All the other fuses are in place.
Engine bay fuses just to the front of the battery.Have you looked at my post above.
The fuse is 50 amp and located in the Engine bay.
Nothing like VW to make things easy to get to a FUSE.This is the Document I have got the information from. You might be looking in Fusebox SD, rather than SA.
I believe SA might be UNDER the engine battery. Further investigation Fuse Box SA under the battery. Count from the L Nos 5 is 50 amp.
It would appear so.So in other words I have to disconnect the battery, take it out just to check a fuse? Is that correct?
