barrymw
I had my windscreen replaced by O'briens AutoGlass (I'm in Australia) and was informed that the ADAS needed to be recalibrated by a VW dealer. When the dealer looked into it, they found that several of the wires had been severed. The first dealer performed a temporary fix and quoted parts with a total cost of about $800, whereas my local VW dealer is saying that an entire wiring loom is required, that is closer to $21,000!! They are also proposing to splice the wires near the ADAS, solder, heatshrink, etc and correct the fault that way. According to my local VW dealership, both approaches are approved by Volkswagen, however one is major works, the other is localised. There are pro's and con's to both, hence reaching out to those in the know!
In terms of the first quote, the parts to be ordered were as follows:
7C0947099GY20 LED read ZZZZZZ 1.00 0 $167.00 $167.00 $183.70
N01713116 FUSE-FLAT 5 AMP ZZZZZZ 1.00 0 $2.50 $2.50 $2.75
000979009E WIRE SET ZZZZZZ 6.00 0 $47.00 $47.00 $310.20
000979034E WIRE SET ZZZZZZ 5.00 0 $47.00 $47.00 $258.50
1C0973119B HOUSING ZZZZZZ 1.00 0 $16.00 $16.00 $17.60
8K0971833 HOUSING ZZZZZZ 1.00 0 $19.00 $19.00 $20.90
I'm not sure why the LED light is included, but I'll have a look once I get the car back. It could be that it was damaged by the windscreen repairer.
My car is still with my local dealer, who are putting together the two quotes, the 'mega quote' and the 'splice and dice'. I'll provide further details when they come to hand.
Given that the work is covered by insurance, what path do people suggest that I take? All thoughts welcome!
