Brendon
Anyone know if it's possible to adjust the rear roof scissor? I've noticed that my roof is not sitting correctly on the rear near side (it may always have been like this). You can get your fingers under the seal.
I've checked:
- that there's nothing left in the roof space
- there's nothing trapped
- there's no wear in the scissor hinges
- that the front roof catches are engaging properly
- the roof is not bent or buckled.
I've also measured the roof's geometry with nothing much to report there either although the near side does sit 8-10mm higher when fully open.
As I understand it, the rear scissor is a passive device. Its elevation is related to the angle of the roof panel. Given the roof is not bent and the front rams/scissor sit down nicely at the front (checked this with a bit of Blutac), I can't see why its not closing properly.
I assumed there was a way to adjust it slightly, but there doesn't seem to be anything to adjust. Any thoughts?
I've checked:
