I have just received my Brandrup air lock through the post but the instructions for use are poor. Are you able to give me some tips on how to fit it please?
The end with the "small" bend you put in the receving end on the floor.
Then you close the booth almost , just so you can reach to take the airlock and place the end with the "biggest " bend gently in the reciving end on the door ,
then just close the booth until it electronic connects like normal closure.
You can now lock the Cali with the remote fob , there is now way you can open the booth....locked as normal.
You just have to try it a few times .
The only thing that can go wrong ....actually two things ever went wrong on mine,
While putting it in and fail , the lock on the boothdoor can close while not in the reciving end....pain in the @ass !
The lock will thinks it's ok but the door is open , slamming the boothdoor close is the thing you DON'T do !..
To solve it you need to push the remote or the knob on the driverseat while trying to release the lock by hand.
The second thing that went wrong on mine was i opend the door having the air lock in .
Took things out the booth and slamed it close not thinking the air lock was still in !
Resulting in a small dent on the inner side on the boothdoor.
@JohnnyP , there is no need for a second person ...you just need to "feel" .
