Phil,
tried to PM you, cant as you are not a VIP Member.
you may want to edit your photo to remove the key part, the close up of the key is sufficient to identify the key type and allow a spare to be made !
There are companies who will reproduce a key from such a photo. It may represent only a very small risk, but it is a risk nonetheless.
If your vehicle is stolen via the key you are not insured
Not sure you can edit if you are not a VIP !Thanks
When I’ve worked out how to I’ll delete the post
I’ll report it to @calikev and ask for the post to be removed for security reasons for you.
Edit: reported your original post
edit : get yourself signed up to VIP member, it supports this great site & resource
It should be a roll pin, simply press it out / back in with a suitable size implement, it is an interference fit so will require some pressure.
edit: a tiny screwdriver works
It should sit sub flush, (push it in a bit more so it sits central in the bore )Thanks pin pressed in with a fork handle
