Chinny
- Messages
- 120
Hello I’m close to buying a 1996 exclusive and was thinking has any one run a let’s say Victron Orion xs 12 12 50 to a good lithium battery then connected that to an inverter then used that if needed to trick the bus it’s on hookup ie to charge the original system or just run the original system if you’re out of power from the old gel battery I’m thinking you could tap into the hookup point inside the bus and plug in at your leisure probably tripling your off grid power if needed any thoughts I’m power mad hopefully makes sense
