If you fit a Thule room you need to move the front arm to edge to make it fit as that’s designed to clamp on the edge of the awning.Next question is why? Thinking aloud If using an awning room you would have more space with the forward arm further out.
Wondering if the spring tension on the awning support legs for stowage is determining the position?
Will have a play when I'm back home.
It’s so you can open the drivers door.Next question is why? Thinking aloud If using an awning room you would have more space with the forward arm further out.
