Awning Rail Seal
Justinitus
Justinitus
Wiltshire, UK
T6.1 Ocean 150
Hi all, I’m looking for some group knowledge please before I present the dealer with yet another fault! Brand new T6.1 Ocean, specifically the near side awning rail (the one without the wind out awning). I’ve been doing some water tests today (canvas, drains etc) and noticed that whilst both awning rails appear sealed all along, there is one small spot that is seeping water through between the bodywork and the rail itself.
Is this normal? Or a potential issue? Would appreciate other owners opinions! Thanks.
Not normal. Should be fully sealed. This is what happened to mine after recall fix in 2019. Fortunately VW Germany will re repair. It will almost be a rebuild, but at least they are taking responsibility. It's a 2015
Oh my, that’s dreadful Patrick. Glad you’re getting sorted though.
Hi there. I can’t another post on this kind of topic, let me know if you know otherwise. We have a 2011 Cali. In noticed this winter that the front section of the rail, where it tapers above the drivers door, comes off, you don’t even have to pull it hard, underneath I can’t (thankfully) see all that rust in the photos above, I just see a lot of rubber which looks like it’s kid of disintegrating.
Anyone else had a similar issue and know what I can do to try and fit it? I could silicon glue it back on. It worried I’ll be trapping in a problem. I’ll try and take some photos
Did u get more info on this & how to repair? I have the same issue
acer
5K
Ian Maddocks
Ian Maddocks
campernologist
t4_generation
t4_generation
t4_generation
