campandfly
Thought I would create a dedicated thread for those thinking of how to top up their starter battery and possibly using a balance cable.
Disclaimer:- This is definitely a Hack, I am not an electrician. You need to be very careful. Different vehicles may have various electrical setups. VW do not recommend charging batteries via the 12v cigarette lighter sockets.(at least in my user manual)
The purpose of making a balance cable was for topping up the starter battery and not letting it get low if you are parked up, eg. not on hookup and are not driving or running the engine.
Yesterday was a beautiful sunny day so I decided to test my DIY Solar setup and balance cable.
I deliberately ran my starter battery down by playing the radio and leaving the headlights on. I don't recommend doing this. It was done purely to test both systems.
Our Cali has the original batteries and is 5 years old.
The leisure batteries were at 13.4volts ~full (I can get them up to 13.7v if on hookup)
The Starter battery after running down was at 12volts ~50%
The Cali was NOT on hookup.
It was a full sun day and the 100watt solar panel was chucking out ~20v 5amps. My Solar controller charges the leisure batteries to 13.4volts.
The overhead control panel was showing the leisure battery level starting at 13.4v and 0.0 A amperage draw below it.
For the test I turned everything off in the leisure area including all lights,fridge and unplugged any accessories.
The overhead Amp reading should be 0.0 A occasionaly it will be 0.2 A as the control panel I think uses a bit.
The balance cable has
2 male cigarette lighter plugs fused at 10amps and with LED lights built in.
It also has an inline switch rated at 240v and 30amps.
The inline switch is really important otherwise you will have sparks flying when trying to plug in the 2nd plug.
I first made sure the inline switch for safety was in the OFF position.
Plugged one end into the kitchen cabinet 12v outlet and made sure the led comes on.
Plugged the other end into one of the dash 12v sockets and made sure the led comes on.
Then turned the online switch to ON.
After plugging in the Balance Cable the Voltage display started to come down. It showed the Amperage drain which on this test was about 3.4 A and reducing. The starter battery voltage started to increase. I quick tested the starter battery voltage via the other dash cigarette lighter socket.
After less than 2 hours with Solar going into the Leisure batteries the starter battery was up to 12.8volts and the draw had reduced to <1.5A at which point I decided to unplug the balance cable.
At the end of the test the Starter battery finished at 12.8volts and the Leisure batteries were at 13.1volts and still charging via solar and was soon back up to 13.4v.
So it worked fine.
It is not something I would do on a regular basis, only if really needed
I have read somewhere that balancing batteries with large differences in voltage produces a fast charge which is not beneficial to the long term health of the receiving battery.
I would not leave this cable attached unattended.
My vehicle is out of warranty so it is probably not a good idea to do it if you are still under warranty.
I would make sure the cable was not used if I were on hook up.
I would not turn on the ignition or start the vehicle while the cable is connected.
I would also turn off all items that run off the leisure batteries as a precaution.
There is no reason this would not work without the solar panel connected although performance would be reduced.
As I stated at the beginning I am not an electrician so any constructive comments are appreciated.
So it worked fine.
