TimR
- Messages
- 172
- Vehicle
- T5 SE 180
In the upper position it lifts it by about 7cm so then its too high
+1 for the zonesleep.I'm looking to buy a zonesleep topper for a bit more comfort on the bed downstairs, but does anyone know if it will even out the difference in height between the shelf mattress and the seat?
Pretty sure they should be level, that's kind of the point
Looking at that picture something doesn't seem right. The infill mattress is horizontal but the seat is not. I have the full VW comfort mattress, but my seat is horizontal when in the down position when compared with table edge. Yours is not.I'm looking to buy a zonesleep topper for a bit more comfort on the bed downstairs, but does anyone know if it will even out the difference in height between the shelf mattress and the seat? I've attached a photo to show the difference.
How thick is the cushion on your rear shelf? Ours is about 7cms, just under 3" and it tapers from the top going towards the rear of the van. I assume that this is so that you can pull it forward a bit and overlap it with the rear of the seat to smooth out the join.I'm looking to buy a zonesleep topper for a bit more comfort on the bed downstairs, but does anyone know if it will even out the difference in height between the shelf mattress and the seat? I've attached a photo to show the difference.
Hi thanks for all the help. Here are some more pics. Mattress is about 7cm thick and tapers at the seat end but even pulled across the height difference is still noticeable. Checked and headrests not obstructed underneath. Bed goes clunk when put flat so locks down. Sounds like it might be a bad old design problem with the mounts in the wrong place from when they used a board instead of mesh? Was thinking of options....
Remove the rear mattress and try the Brandrup ixtend thin pad with wire mesh in top position.
Remove the rear mattress and replace with vw comfort mattress (seems bulky)
Buy some approx 2cm hard foam and cut to the shape of the rear mattress to sit underneath.
Anyone have any other ideas or tried any of the above?
Did you find a solution gregspam, sounds like you have had the same issue?
I assume vw must have "fixed" the issue fairly quick.
View attachment 11847 View attachment 11848 View attachment 11849 View attachment 11850
Not sure how you drew that conclusion from the limited original picture? Subsequent pictures look normal to me.
Not sure if you see this also, which could be related, but when I tilt the shelf on the non locking fixings and move it to a different position where the bolts rotate/slide in, they don't always line up perfectly and take a small amount of persuasion to align, like the frame isn't quite true. I'm pretty sure it is though, so maybe that's consistent with the fixing holes being a bit off spec. It certainly doesn't feel like German precision engineering anyway! Small gripe though.
Very simple. I enlarged the photograph on my big screen iMac. Made sure the bottom of the wardrobe was horizontal by adjusting the angular rotation of the photograph. At this point I could see that although the shelf mattress seemed horizontal, but the seat back did not. On my vehicle the seat back sits a little lower than that in the photograph.
You obviously have better eyesight than I have, and hindsight is so useful.
Yeah seems like mine is the same, tried to move it to the top fixings and bolts didnt quite align.
The VW Comfort mattress or a full length topper would solve that problem.
Well the VW Comfort mattress works fine on mine. Obviously not a common problem as cannot find any mention of this on the Forum or elsewhere. I could be wrong but I still maintain that the slight elevation of the seat back over the rear mattress is as designed and that once bodyweight is applied it will be compressed and level so that you are just left with the join. In which case the fairy story of the Princess and the Pea springs to mind.
