Beep noise when unlocking 07 plate T5
BigPritch
BigPritch
Wirral
T5 SE 174
Have tried searching Forums, but can't find anything.
Is there any way I can disable the 'beep,Beep' noise whenever I unlock the van ?
Have to press the unlock button 3 times to get the side door open, which as you can imagine, 6 beep beeps, is annoying.
Is there something I can do with the Fob to change anything ?
Many thanks
To stop the beeping you will need a diagnostic scanner like Carista,OBD11 or VCDS to code it out. On my vehicle I coded the beeps for when my vehicle is locked.
Thank you, was hoping I could do it without taking it back to the garage. At least I know, thanks.
Mine only beeps on unlock.
If you go on the T6 forum you can ask a member close to you who has VCDS to code it for you, for a few beer tokens.
