K
Kjetil
The probable source of leek is definitely left front pillar since I discovered water there, see pic. At least one of the leaks. I would believe some of the soak was from an older leak from the sliding window above the sink.
Thank you everyone for all the leads.
Now, next step is to remove the trim but where do I start? If I bend it open slightly I can see the drain hose. Where would the leak be, upper or lower connection?
