G
gateway77
Hi
looking for some advice on a broken lock mechanism for the fresh water fill up.
i.e. the lockable cap next to the external power socket, rear nearside of van.
It looks like the internal fixing ( black cylinder approx 30mm deep) that the cap locks into has been broken or just come loose, I'm not sure which.
The result is that once locked I can just turn the lockable cap around in any direction (which i think is normal) but I can also pull it straight out of the neck of the tank.
Has anyone had this happen and resolved it successfully?
I have done a search but maybe am not putting the correct terms in - so if anyone wants to point me in the right direction it would be appreciated.
My assumption is that I can use some sealant to fix the gasket in place and then continue to be able to lock the cap.
Much obliged for any tips or advice.
