Bungee for the tent
Sp0_0k
Sp0_0k
T6 Beach 4Motion
Anybody who has the bungee rope for the bellows can you tell the length of the rope?
Want to make it myself. Also what diameter is used on that product?
Think I have to order around 10-12meters and planned 8mm diameter.
If making yourself make sure you use a good quality bungee or it will lose its elasticity, I think I read somewhere that the one of the shop uses a higher grade material that is used on boats.
You will need the quick clip it is designed to hold the bungee but also come undone if it snags
No worries I can manage to tie a bungee rope. :)
you could try putting a tape measure around your tent
you could buy one - cut it in half and measure it.
you can then be sure your one is exactly the right size.
Shop acts weird. "There are no shipping methods available. Please double check your address"
Something tells me you don't need to check where you live, you might already know that :headbang
I would highly recommend getting a bungee from the shop - or similar. As it turns out I have 2 as my dealer surprised me with one and I bought one in the forum shop after reading the recommendations. I'd offer to sell it to you but suspect with postage cost you'd be better off sending a PM to the forum shop and organising something directly from there.
Thanks, I might just get one from the store. Need to convince the shop about my address though ;)
IF you do it yourself, be aware that the bungee robe you chose do not color when wet. I guess you would be sad if you would get stripes on your tent ;-)
Might just get it with other stuff here.
How does the discount on this store apply?
Any limitations on methods of payemts, address etc?
Afraid to order anything with recent surprizes with discounts :(
Thank you.
Any input on this error?
""There are no shipping methods available. Please double check your address""
What country are you and I will add the option
Czech. It worked for one product but as soon as was adding other to cart it gave the error.
It depends on size and weight. Can you pm me what you would like to order and I will work out the discount and postage for you.
ChristopherW
KGCali
KGCali
Mr & Mrs B
Mr & Mrs B
Mr & Mrs B
