I believe factory fit is cheapest.Is it better to buy an original built-in removable towbar ( for a bikerack), or only the preparation for the towbar, and add a fixed or other towbar later for a bike rack. Maybe the latter is much cheaper?
VW Dealer will probably use a 3rd party to do it but charge you a premium to organise it. Find out who they use and go direct.I bought my coast off the showroom, but it came with the tow bar prep; because I’m seriously considering getting an Eriba to tow I’m exploring my options to have a tow bar fitted. Because the van only has 400 miles on the clock I’ll probably get VW to install it, but as yet I don’t have any pricing.
hi bought my 13 month old cali in oct had a towbar fitted at vw van centre cost was 1230 pounds.hope this helps regards.I bought my coast off the showroom, but it came with the tow bar prep; because I’m seriously considering getting an Eriba to tow I’m exploring my options to have a tow bar fitted. Because the van only has 400 miles on the clock I’ll probably get VW to install it, but as yet I don’t have any pricing.
Thank You !hi bought my 13 month old cali in oct had a towbar fitted at vw van centre cost was 1230 pounds.hope this helps regards.
Mine had a “dealer fitted” towbar from new. Despite having been supplied with tow bar prep wiring the towbar socket was incorrectly wired. So you don’t always get what you pay for, look at independent fitter.I bought my coast off the showroom, but it came with the tow bar prep; because I’m seriously considering getting an Eriba to tow I’m exploring my options to have a tow bar fitted. Because the van only has 400 miles on the clock I’ll probably get VW to install it, but as yet I don’t have any pricing.
It is behind the rear wardrobe above the water tank lid, stuck to the external bodywall with some tape. Besides fitting the towbar the underbody shield L rear is removed to locate the rubber bung, towbar plug fed through and connected to the prep socket. Oh, the rear battery locker cover is removed and sometimes rear leisure battery pulled out but doesn't need disconnecting.Just going off what vw Liverpool told me ...
I’m not saying it’s the way it has to be done.
Pf Jones run there own cabling under the van
Vw told me there’s is behind the kitchen so the towbar prep is also there
Sounds a stupid place to put it but this is what I was told
Yep.I priced up a dealer fit one when I looked at buying a demo Van with prep,
The dealer told me they have to remove part of the kitchen to do this and it was around a grand!!!!
I seem to recall it might be easier to access the socket by removing the hook up /water filler.It is behind the rear wardrobe above the water tank lid, stuck to the external bodywall with some tape. Besides fitting the towbar the underbody shield L rear is removed to locate the rubber bung, towbar plug fed through and connected to the prep socket. Oh, the rear battery locker cover is removed and sometimes rear leisure battery pulled out but doesn't need disconnecting.
I get the impression the Dealership didn't want to do the job. Probably a fixed price by VW.
