Think there are a couple of screws to take out, long time ago I had mine apart and door off without dismantling cupboard.Hello everyone.
I need to replace/reassemble the sliding door of the rear cabinet because it is broken.
Does anyone know if I have to disassemble the entire cabinet? I can't find instructions anywhere...
Thanks everyone!
Thanks!Think there are a couple of screws to take out, long time ago I had mine apart and door off without dismantling cupboard.
Well done.@jeff you was rightjust 2 screw was inside.
I report the guide line that i found on other site, if will be needed for some other
simply remove screw from the retainers top and bottom with a screwdriver, remove shelves for access, slide out the damaged shutter and insert the new one.
– Remove the shelves and unscrew the plastic stays both top and bottom of the tracks. Set them aside.
– Remove the old tambour door.
– Clean the tracks with a pipe cleaner and vacuum.
– Wipe with a rag and pipe cleaner or wire.
– Carefully insert the new tambour door into the tracks and gently slide the door back and forth in the tracks.
– Replace the plastic stays and screw in place.
– Install the shelves.
