O
Oldbramwell
- Messages
- 11
Cali's without a rollout awning are delivered with a rubber insert in the awning rail (in place of the rollout awning). The rubber insert has a C-slot. Naively, I assumed this was for attaching canopies using 6mm Kador strip. But there seems to be a consensus that the the rubber insert is about as much use as a chocolate teapot for holding 6mm Kador under anything but the slightest tension. Playing around with better ways of attaching Kador-equippped canopies to our van, I've tried sliding the rubber insert into the awning rail upside down!! With this arrangement, holding 6mm Kador in the C-slot looks much more hopeful. The tension would be tangential to the slot, not radial to it.
Has anyone tried this? Does it work any better?
Oldbramwell
Oldbramwell
