T
tritone30
Hi All,
Does any one know of a Cali Configurator, i am finding the brochure a bit confusing.
Tone
Tone
You are not wrong there. Not sure about a configurator but if you read up on the T6 section of this site a lot has been discussed re options and what they mean, should help a lot.i am finding the brochure a bit confusing.
Not in the UK I'm afraid. You are in the fortunate position that there are answers to most issues re the options on here. If you can't figure one out just ask here or your dealer if you are confident in them. Some of the technical options can get a bit anal and the glass options complicated. Between this board my research and the dealer I git there in the end. Better to ask a daft question that get it wrong. Good LuckHi All,
Tone
TYou are not wrong there. Not sure about a configurator but if you read up on the T6 section of this site a lot has been discussed re options and what they mean, should help a lot.![]()
Thanks, On the accessories list under Heating and Ventilation, there is a Water Auxilliary Heater for the California, at about £804. My dealer tells me that this is used to warm the engine to its correct operating temperature before driving off! I thought it might be used to warm the van interior.Not in the UK I'm afraid. You are in the fortunate position that there are answers to most issues re the options on here. If you can't figure one out just ask here or your dealer if you are confident in them. Some of the technical options can get a bit anal and the glass options complicated. Between this board my research and the dealer I git there in the end. Better to ask a daft question that get it wrong. Good Luck![]()
T
Thanks for clearing that up, we have just had a look at the pennys and decided to go for the diesel heater as you suggested. Many thanks.Ocean has all the heating extras installed as standard, Beach has none...
Auxiliary heater is a booster heater for coolant water to heat up engine more quickly and kicks in below 5 degrees.
Parking heater is the inside heater - but there are two types!
1) Uses residual heat from engine coolant
2) Air heater powered by burning diesel which is not reliant on engine heat
Option 1 is the £804 extra for the Beach and includes the engine warmer, but if you want overnight heating, the diesel burners are a must - but they come at a price...
The Ocean has Both the engine warmer and a diesel burner (with remote) as standard.
We've ordered a Beach, and have bitten into the savings to put the same heater package in as the Ocean.
I made the same choice, comfort now (or at least when it's readyThanks for clearing that up, we have just had a look at the pennys and decided to go for the diesel heater as you suggested. Many thanks.
Hi All,
Tone
Also be careful as the UK options are differentThere is one but it's all in German.
http://www.volkswagen-nutzfahrzeuge.de/de/modelle/california.html may be of some use.
yes but at least uk is getting one nowThat's the old price shown, it will all change in the 1st June
Can't argue there It makes life a lot easier and totals it up for youyes but at least uk is getting one now
but it tells you they do NOT turnDear God !!
Comfort seats are still an option in there..........![]()
Good point Andy, and definitely a step forward from the original brochure, where I got caught-out. Can't see them being a big seller though.but it tells you they do NOT turn
