foxy-rob
- Messages
- 15
If you have the SatNav then you have a pretty accurate compass display on the MFD.That looks good.
There is always something that can be improved. It took us a while to find our "camping workflow" which was important to us to decide what changes we would like to add. Following this idea we change the following during the years:
Pull out drawer in the boot
2nd drawer under the bench
Shelves in the big wardrobe
Adding additional drawers in the wardrobe
Got VW to install a dashcam
What I am still looking for is a compass (that halfway works). It is just a gizmo, but difficult to find something that is affordable and works.
Happy California,
Eberhard
Lots of Smartphone Apps that provide a compass.That looks good.
Happy California,
Eberhard
what about compass on your mobile phone?That looks good.
Happy California,
Eberhard
Got a smartphone Eberhard? My iphone has a decent compass.That looks good.
Happy California,
Eberhard
Plenty of inexpensive car compasses on amazon (and your satnav has a compass).I have a smartphone, but I used this for Google maps. So it is in the clove department connected via USB cable to the radio.
I guess I will get an used, entry level mobile phone and use this as a compass (I can't see any other way). I will get the power from the dashcam (splitter).
The reason why I have not done it is, even thought it is an used entry level phone I can't leave it in the van, also I might need to take it off if I want to close the blinds (I have to take of the dashcam aleady if I want to close the blinds).
As if I had not other problems... .
Happy California,
Eberhard
Hi RobWanted to share some recent modifications we’ve done to our Cali. Without the info we found on the forum we wouldn’t have done it. So thanks to all who’ve posted tips on wardrobe shelves and the drawer system. Absolutely brilliant!!!
I understand the 'gizmo' attraction. And indeed most car compasses are not more than toys. You should look for sailing equipment, with wide range of precisions, LED-lit, sunshades, magnetic compensation options, heat resistances,...Correct, I tried a standard car compass from "Richter" (German company .. pff), which was a waste of money.
So far I have not found a way in Google maps to show the map and a nice compas rose.
Navigation California,
Eberhard
I got a local electrician to fit it & had the USB connection as well - it really is worth doingLooks good. Did you fit the extra mains socket in the wardrobe by yourself? Any tips on how to do it?
We bought the shelving kit and the drawers from Calicap (Germany) - don't be put off by the fact they're not in the UK - check out previous threads relating to them. It was expensive but so efficient & the build quality is fabHi Rob
very nice indeed, where did you source the shelving from ? Was it a kit or something you made up ? Nick.
They work off both - local electrician fitted them & we have one above the sliding door for night light - well worth itIs the plug socket connected to the hookup or the inverter?
Many thanks RobI got a local electrician to fit it & had the USB connection as well - it really is worth doing
