Mike C
- Messages
- 3
Help: the central control panel won’t turn on at all in my 2007 California!
I’ve checked the auxiliary batteries and they are reading >12v i.e good. The fuse (under the passenger seat) is OK but a voltage meter reading here shows 4.4V (and similarly for the water pump supply at its fuse). Can someone tell me whether these circuits supposed to run on lower voltages or should they be more like 12V?
I’ve seen the blogs about the common earth shunt fault causing problems with the control panel. Does anyone know if this could be the problem with the panel not turning on at all?
Does anyone know where I can get a wiring diagram?
Many thanks
Mike C
Many thanks
Mike C
