CG600 luggage storage inserts
MX447
New Zealand
Grand California 600
Hello, I have purchased a used CG600. I can't seem to fund these luggage / storage area inserts. Any chance they are stroed somewhere in the van and I just haven"t found them yet?
If not, I'll go back to the original owner and see if he still has them but thought I'd check first and see if they are in a creative spot in the van.
Where does everyone store these panels when they arte not in use?
Thanks!
You will probably need to ask the previous owners. I only use one in the van, the second one is in the attic along with the original table.
There’s a limited number of places they could be - under the mattress, one of the back cupboards, over the cab storage - there’s no ‘stowage storage’ for them so sounds like they’re missing.
Agree with previous post. No magic storage place to my knowledge. Mine both live in my garage at home. Ask previous owners and/or dealership you bought it from incase they removed them when valeting. If you do want to use that type of retaining system it’s a lightweight plywood board. We don’t use them as we use the right side cupboard for general storage and I’ve swapped the hinges to the left side to allow access from the kitchen. I’ve also fitted retaining straps to the left side ply panel in front of the fresh water tank to secure items when travelling. As you use the van you will decide how best to use the garage area and secure the types of things you put in that area. There is a lashing rail running the length of each side that these loops slide into to allow loads to be fully secured. https://amzn.eu/d/auiH8iD
