Theodora
Does anyone know what the function is of these clear plastic strips on either side of the roof-well – and what would happen if they were removed?
2 years ago, after I noticed they were starting to buckle/dislodge and paint was rubbing-off from the top-edge just above them (due to excessive pressure from the roof front-edge rubber seal when closed), I managed, after a long saga, to get VW to finally admit a manufacturing/assemble fault and repair this under the warranty.
They adjusted re-positioned the pop-up roof slightly towards the back (to relieve the pressure), cleaned-up and repainted the damage and replaced the 2 clear plastic strips on either side. This was 8 months ago and I haven’t had the roof up this year. But now I see one of the strips is starting to buckle again, which indicates to me that further positional fine-tuning in needed.
I assume they must be there for a reason, but what would happen if I just removed them completely?
