Topman
- Messages
- 91
- Vehicle
- T5 Cali on order
Please could some advise what I need to buy to connect my 230V extension lead too on the electric pitch boxes on French campsite, is it some kind of Adaptor ?
Thankyou
Thankyou
Forget at your peril along with an extension lead to increase the length of your hook-up cable.
I run with a 30 metre and a 20 metre cable and again this holiday I needed both.
Indeed. That's assuming you've done the volt drop calcs and made sure you're at least 94%(or whatever the French equiv is) of supply voltage?Connecting two extensions together with the 16amp plug and socket is perfectly safe. As Sadie has said, sites often have them available to hire.
Alan
Be a shame if the Mrs's hair dryer overheated and burnt the van out. I'm sure the insurance company will be fine ;-). A couple of other things I'd check but I'll not bore you. Crack on! LOL.
Well we could discuus increases in R1R2 loop resistance and possibly exceeding max limits/disconnection times of the breaker as a result.....but we wont.A voltage drop at about 2% can start to become an issue when drawing 6 amps over 50 mtrs of cable.
This is assuming you plan to boil a kettle or use a hair dryer. Mostly the current draw is much lower, just about 1 amp on average with the fridge and charger running normally.
Carrying that amount of cable becomes a pain as well though.
Most of us, I would guess, only have a 20mtr cable on board and adding another 10 or 20 mtrs to that shouldn't drop the voltage too much to notice at 6 amps, well below the 3% or below required.
I carry a 20 and a 10mtr cable on board, having got caught out last year.
Alan
never had a problem, have just done a 4,500 mile trip and every campsite in corsica, sardinia, sicily, italy and france had the 16a blue sockets
john
