Are you sure your Charger is under the Fridge. On my 2014 it is above the Rear Leisure Battery. I think they changed the position around about MY 2014, so about mid 2013.Thanks. Was more about accessibility. Can I get to said wire through the small circular access hole in the cupboard under the hob. Don’t need a ground / earth for charger and anyway would need to take out fridge to access shunt (I believe). Unit has a diode so one way only leasure to starter so no problem when engine running. By running through load out on solar controller I can choose to charge starter only once leasure on float and also see how much Amp-hour starter is needing each day.
