A photo would help.Could any one advice me please on what the control panel means on waste MO. And two straight ish lines //
Ok I will take one ThankyouA photo would help.
No problem. I’m sure we can sort it out.Ok I will take one Thankyou
Empty the Water Tank and then leave the drainage valve in the halfway position.Thankyou
I’m not sure also if I should completely empty my water tank so the water dose not freeze or leave enough over the pump Hope this is not annoying I’m a novice
You’d probably have got closer to cracking it on Tuesday!Oh gosh Monday I would never have got that thanks .
