Hi. I have just finished trying the waterproof version of the new Comfortz mattress cover.
I would first like to say that I do not have the VW comfort mattress but the Brandrup version.
I managed to get it on, it is very snug, but seeing as the cover was never designed for this setup its a remarkably good fit.
Both the feel look of the cover are excellent.
With the Brandrup, the standard rear short VW mattress is retained and the Brandrup is a full length topper. Inserting the Brandrup mattress into the Confortz cover is very simple, you then need to also insert the VW short mattress into the rear pocket of the cover. This is tight but easy enough to do. I fitted the whole cover without needing to remove the mattress from the van.
The Brandrup mattress must however have slightly different dimentions especially at the rear drivers side corner. This causes the mattress to not properly fit the cover as can be seen in the pictures below. As this seems to be a minor fit issue, I will leave it on. I want to see if the memory foam conforms better to the cover with a little time.
Nick has said that adjustments to the fit could be made at his factory to accommodate this.
Many thanks to Nick at Confortz for giving me the chance to try this. I will update this post when we next sleep on the lower bed, to let you all know how it feels.
Cover looks great and very practical
Tight fit in rear offside corner, but looks better since this picture taken.
Fit is fine in other corners.
Looks so much better than the blanket I had thrown over the mattress before.
