D
Dephie
I wonder if anybody else has experienced this.
Today I used our 2014 beach as an office (no electricity used) just in and out, when I had finished I couldn't lock the doors with the key fob.
So I discovered a flat starter battery is the culprit, now the interesting bit when I go to check the battery I discovery that the DRL's are on although very dim. So my question is: Do I have an electrical problem with the DLR's causing a drain or are the DLR's on because of the low voltage of the battery messing with the Canbus?
Original battery Moll EFB+, also has a solar panel connected to the leisure battery.
I have connected EHU to see If this charges the Starter Battery which currently measures 6.06V.
I last started the beach about 3 weeks ago and haven't noticed the DRL's on before.
Any help from your wealth of experience would be appreciated.
Steve
Steve
