After 3 Years ownership and many nights away I found out something new about the California.
I thought ALL the blinds in the rear of the California were straight forward spring loaded roller blinds like the tailgate blind that you pull out and clip to the top of the rear window. I thought the side blinds and the sliding door blind were similar the only difference being the Aluminium Extrusion Handle Running in a tight channel, either side, with friction holding the blind at whatever position you choose.
I was wrong. Whilst away in Oxfordshire last Sunday night I put the Off-side rear blind down to find it wouldn’t stay down and the Handle seemed very loose in the guide/side slots.
Closer inspection showed there was a fine braided wire running the length of each guide slot and at the bottom a black plastic slider with a horizontal tab on it. Angling the Aluminium Handle to get it out of the slot showed it was a hollow extrusion with the blind material clipped in the top and a slot below, at each end, the same size as the black plastic sliders tab.
Using a small screwdriver to lift the slider up the wire on each side it was easy to push the Aluminium Handle onto the slider tab each side and fix the problem.
