Diesel heater
Kencovwc
Kencovwc
Kenco
Cornwall
T5 SE 180
My heater will not switch off. The overhead panel is switched off. But after a while the heater starts to blow out hot air while we are driving, as soon as you turn the ignition off it stops. Does anyone know which fuse is for the auxiliary heater as it doesn’t show which one it is in the owners manual ?
Are you sure it is the Diesel Parking Heater that is running. It is only powered by the Leisure Batteries.
Do you have the 3 Zone Climatronic AirCon heating system?
Is the Rear Zone set to a high temperature?
Is the Hot air coming from the vents in the base of the Drivers B pillar OR from the vent by the Rear Bench seat next to the sliding door?
Hi. The rear heater is switched off. The hot air is coming out at the vent on the b pillar at the bottom by the step which is the vent that comes on when I switch it on at the overhead control panel. The control panel is off, but when we are driving the vent has hot air coming out of it. What I was going to try is to take out the fuse see if that stops it, but I can’t find anywhere that tells you which fuse is for the auxiliary heater.
While you're in there, you might as well reset the Control Panel by pulling its fuse as shown above and replacing it.
Ok thanks
According to your Avatar info you have a T5.
No need to pull any fuses on this Control Panel.
Check Control Panel Diagnostics.
Control Panel Off and wait 30 secs
Control Panel On
Press and Hold R lower button and then press Control Knob for 5 secs.
New Hidden Menu . Scroll to VW Diagnostics.
If there are any codes shown, take note and then Reset/Clear.
Return to Main Menu.
Switch Off Control Panel using L lower button. Wait 30 secs and Switch On.
Try Roof/Heater or Fridge
For those of you who don't know, if you ever get any problems with roof stuck or any other error say with the heater or fridge, you are able to access the hidden menu in your control panel as used by the VW Engineers.
Access as follows:
1. Hold down the centre of the rotary button together with the menu button (button below with the squares on it)
2. You will get the hidden menu.
3. Rotate the rotary button to get to "VW diagnose" and select this by pressing on the centre of the rotary button.
4. If no errors are present it will display "no errors"
5. If Errors are present then a list of errors will appear
Make a note of the errors.
6. Press the centre of the rotary button again to delete all the errors
7. Repeat process above just to check that errors have dissapeared!
8. Re-configure the time and date if neccesary.
Any problems should be resolved assuming these are Electronic and not Mechanical.
Error Codes from Control Panel.
1 = 1 = Pop-up roof
2 = 2 = Plumbing Heating
3 = 3 = Cool box Cooler
4 = 4 = Sewage wastewater
5 = 5 = Fresh water
6 = 6 = Outside temperature
7 = 7 = Battery
Error Code Defect Fault
1010 1010 Short-circuit to (earth) roof
1001 1001 Fuse / short circuit to (plus+) roof
1100 1100 Short-circuit output Roof "on"
1101 1101 Fuse roof "to"
1110 1110 Short-circuit output Roof "to"
1111 1111 Fuse starting Roof "to"
2100 2100 Short-circuit output heating on / off
2101 2101 Fuse output heating on / off
2001 2001 Interrupt input heating 30
3100 3100 Short-circuit output coolbox
3101 3101 Fuse interrupt output coolbox
3001 3001-J698-cooler input error "Active"
3010 3010 Short-circuit input icebox "actual temperature"
3011 3011 Interrupt or fuse input icebox "actual temperature"
4000 4000 Short-circuit to ground water level sensor
4001 4001 Fuse circuit to plus water level sensor failure
5000 5000 Short-circuit to ground water level sensor
5001 5001 Short circuit to plus water level sensor failure
6000 6000 Short-circuit to ground temperature sensor or for outdoor temperature
6001 6001 Fuse / short circuit to plus two temperature sensors for outside temperature
7001 7001 interrupt input interrupt input D +
Have you got any further in sorting this problem?
This had happened to me. The panel in the back where the back seats are , head height just above side window drivers side was switched on!
Control Panel On
Access as follows:
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
Interesting these error codes. I own a T6 Coast. Are they also valid for a T6?
I do not need them now, because there are no problems, but they might be handy in the future.
Greetings from The Netherlands, Hans
The heater on my T5 switched on as a part of the warming up process for the engine on colder days. I used to get strange looks because of the smoke / steam coming out of the side of the van!
It is Control Panel Specific.
If you have this Control Panel - Yes.
Different Heater.
There are 2 diesel heaters on most Californias SE/ Ocean.
Parking Heater controlled by Control Panel - Only.
Engine Coolant Heater automatically switched on when engine started if ambient Temperature 5c or less. Some vehicles sold in Nordic countries have a controller for this Heater to pre-warm engine. This can be retrofitted by using 3rd party equipment.
Control Panel On
Access as follows:
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
That is a really helpful post - thanks. Would that process be the same for a T6 - or just a T5
I think it is the same panel according the knobs. Only the picture is slightly different. But that is probably because my cali has no electric roof.
You can but try as detailed.
Control Panel On
Access as follows:
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
Please ......Never leave this club, you know and contribute so much that's so helpful
Control Panel On
Access as follows:
1 = 1 = Pop-up roof
5 = 5 = Fresh water
7 = 7 = Battery
WG is still a legend! Thanks
Hi I have tried to press the rotary knob to get the Diagnostics Up but I don’t have a button with squares on it, my control panel is like the one pictured, several posts ago.
Use the return button (with arrow on it).
