Thepiper
I notice when cleaning my Cali that there is always some grit gets trapped between the wheel arch trim and the sill at the bottom of the door. I pull the trim back slightly to allow the grit to escape. This time I took a deeper look and in fact there is a huge amount of crud collecting in the sill behind the wheel arch (on both front sides). The trim is not a tight fit and it is obvious where it all gets in. I removed a fair amount but I suspect that a great deal is starting to work its way along the inside of the sill where there is nothing can be done to remove it. Anyone else as particular as me when cleaning it? I like a nice clean finish to the outside of the van, but the main reason I wash it is to get rid of the crap that can eventually cause corrosion which is why I pay attention to all the nooks and crannies that are exposed to the most water and dirt (i.e. around wheel arches and underneath the vehicle.
