Driver bit for Counter Sunk Screw on the Sliding Doors
W
Wanno10
Hove
T6 Beach 102
Hi all,
The top mechanism on our sliding door has worked itself loose and the door doesn’t shut smoothly. Looks like i just need to tighten these two screws up but never seen a screw with so many star points. Does anyone know where to get the correct driver bit for these?
Looks like a triple square spline bolt, will check my t5.1 to see if same and confirm size.
a normal allen key will fit and tighten that . make sure its a good fit ,it doesn't need to push on all the star points. other than that you need to go buy a set from screwfix or similar,always handy to have.
I'd be quite careful - there's not going to be much metal engagement with a hex key, be OK to stop it wobbling but I wouldn't try and torque it up. Better to get the right bit.
Thanks everyone. Turned out it was a M8 ‘Spline’ bit I needed. Got a set from Halfords for £13.99
and fixed the door in less than 5 mins - 4 of those minutes were winding out the awning so i could get the wrench in place
